Oil pan question
Toyota h8r
Formerly KILLERMK3
Jan 24, 2006
187
Sylvania ohio
I have a quick question about my n/a oil pan. The other day i had the jacked up working on the exhaust and noticed something odd. On the side of the pan there is a nut looking thing welded to the side. Is this a gte pan? Is the nut thing for a oil return? If it helps, the pan is a green looking and the motor is a orange color. Sorry about lenght but knew to complete. Thanx for all help in advance!
Toyota h8r
Formerly KILLERMK3
Jan 24, 2006
187
Sylvania ohio
I was wondering, if i choose to turbo my n/a, what would i have to change other than exhaust man. turbo and ic stuff? A friend at a local import shop said i would not have to switch ecu, intake, and injectors. Just a side note, i would not raise boost levels and i know of oil cooler line tap to feed turbo, but what line do you use? I assume that the lines have to be stainless steel do to heat or can you use rubber oil cooler lines? Also, how to connect oil drain to plug? Thanx for helping a newbs:)
