^ I believe he was saying to pull the engine/trans together... 2 hours isn't a stretch at all. If you suck and/or have never done it, it might take you three. :icon_bigg
To be fair, he did forget about the fuel lines,clutch slave, speedo cable,drive shaft, and taking out the shifter/radiosurround from inside the car... actually, quite a few steps were forgotten... Heater hoses, ground wires, heater control plug from the harness, the harness for the alarm horn... brake booster vac line, throttle/cruise cable, oil cooler lines... and thats just off the top of my head.
