You dont have to pull the motor to do the oil pan gasket, hell I have done many rod bearings with the motor in the car. You will need an engine hoist though. Anyways just take the nuts off the motor mounts, unscrew the sub frame bolts about an inch or so out, hook engine hoist to motor and lift it up until you hit the trans tunnel, if you need more clearance you can take off the trans mount too. Now you will be able to get to and undo the oil pan bolts. Once their all out drop the pan down, you wont be able to get it out because the oil pump will be in the way, so take it out and drop it into the pan. Then you can take the pan with pump in it out of the car. Its tight but doable, much better than pulling the motor IMHO. Also air tools really help here because you will wear yourself out unscrewing all of the bolts by hand. Within a few weeks hopefully I am putting some bearings in a friends turbo supra 87, so i will try to get all pics and do a complete writeup.
