Oil pan Gasket for a 1jzgte
SirLoki
129
Fullerton
viperkillertt said:
Thanks! I searched, but i didnt see the post. Anyone have good tips on making it. Do you just make a snake and then put it around? What do you suggest?
Thanks!
get a paint scraper or gasket scraper and be sure to remove all of the old gasket and make the surface very clean. then apply the fipg, install the pan and torque the bolts down evenly.
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
I use a blade from a utility knife.
Yeah, just put a snake of it around. You don't need a whole lot, except where the pan goes around the crank, you need a little more there.
Don't just use plain old silicone either. Go to the dealership, and get a tube of FIPG. It's a couple bucks, and is 100x better then any silicone you get at the parts store.
