I am asking a simple question. I bought a 87 n/a 5speed 4 $200. The reason it was so cheap was the subframe was cracked and clutch prob. After removing the trans i discovered some bad looking things. First thing, no material on clutch and second, oil is leeking from the head area. i`m new at supra ownership and i am not going to quit at it. The clutch issue is not to big because no damage to flywheel and such, it was an after market plate because of center springs were solid bushings. My last question is it ok to use cheap clutch disk after having an upgraded disk? Just 4 fyi, if anyone from sylvania ohio or toledo knew Phil with the 89 red turbo targa thats the prevois owner.
