Oil leaking issue.
fonz87
89 Turbo!!!!
Nov 17, 2007
642
Streamwood, IL
My Drain plug is been leaking oil with the bolt plugged into it. I have a Copper Gasket installed with the Bolt. The Drain plug is not stripped. I always handed tighten it before using the wretch. Its dripping oil and it's annoying me ?? Anyone else had this problem ?? How can i stop this ??
Btw, it's a new Drain plug Bolt. it did it on the old bolt also.
mv520
Midwest
sorry to bump. but i have the same problem. it started leaking after i got a oil change at at a shop :icon_evil . so i installed a new plug with rubber gasket and its leaking. what were ur guys solution if u had the same problem. thanks
fonz87
89 Turbo!!!!
Nov 17, 2007
642
Streamwood, IL
Someone mentioned here to go to toyota and ask them for a paper gasket for the drain plug. it's like dollar something, i installed it and haven't had a problem since then. I m planning on getting a new oil pan next year.
zdatsupra
69
florida
i have the same damn problem on my new engine.
seems like this is right up there with bhg.
maybe i will try paper like someone mentioned.
ive done copper and now teflon.
kamikazemkiii
1,219
North Carolina
Have u made sure that its not leaking somewere else and just collecting their?
i had a problem like that also, i got a new washer from autozone and it stopped
mv520
Midwest
I received my fumoto valve in today. when i took off the old drain plug i noticed a small chunk missing of the starting threads :3d_frown: :aigo: :cry: . i installed the fumoto valve. it leaks a bit slower. any suggestions...
mkIIIman089
Ohio
The threads have nothing to do with sealing the oil drain plug. You still need to make sure you're using an OEM Toyota gasket in there.
zdatsupra
69
florida
mv520;1418303 said:
i ment to say thread missing from the oil pan. whats the part number for the gasket then..
I went to the toyota parts counter, he had oil pan gaskets sitting there in a candy jar.. Was giving them out for free.
It did look like paper, nothing special but sealed for me.
Does that valve cause any loss of clearance? It looks like it could hit something on a lowered car...
grimreaper
2,180
Dallas
At some point the plug was over tq'ed which seems to be confirmed by your "breaking" threads. It deforms the pan in that area making copper gaskets a joke. Napa has gaskets like this behind the counter. Bring gthe bolt in and match it up. I use a paper one (feels like thick cardboard) and covered it (VERY THIN layer) in gasket maker. Works perfectly.
akito
Keep Laughing.You're Next
Jul 31, 2006
1,568
Springfield/Va
What i do at work is use a later model trans plug gasket from another toyota, the aluminum one. Then be4 screwing it in, i add a little bit of FIPG, like a size of a finger tip. It hasnt leaked since i use that method.
