Oil leak....
sathu
125
SJ, CA
I had oil leak before with my camshaft oil seal and I replaced that along with my timing belt and the rest of the belts. Now, a month later ther is oil leak again. This time there seem to be oil behind the water pump and the power steering. Can the camshaft seal be leaking oil that can reach all the way to the water pump and the power steering? Right now I am waiting to see if oil will leak down behind the crankshaft pulley through the hole under there to confirm that it is indeed the cam oil seal again.
My turbo oil seal is also gone, can this cause the oil pressure to go up and cause a leak throught the cam seal and maybe other places I don't know about?
sathu
125
SJ, CA
Well I'll check the cam cover tomorrow and see if it does leak or not. My bro say he replaced the cps before when it leaked. I'll take a look at it also to see if that is the problem or not.
