Last week I installed an oil catch can so stop the oil vapor from the valve cover getting back into the turbo.
I set the valve hole into one of the can input and the other hole is attach to a breather filter, the small air filter thingy. The throttle is connect to the turbo to bypass the valve cover completely.
After that installation, I took it out for a drive and now I am getting oil leak in the front of the engine where the water bump and pulley is.
At first the water bump was thought to be broken but the coolant level is still the same in the radiator and the tank.
Does anyone know what in the front of the engine can leak oil that drip down to the undercover? I tooked the cover off and took a look and got no freaking clue where it is leaking from, it's a freaking mess of dirt and oil down there to make anyone confuse :dunno: .
I know it oil leak because I took it for a smog check yesterday and it left 2 pile of oil on the shop floor lol and it barely pass the HC part of the test.
So yeah, anyone have any previous experience with this kind of oil leak?
