Hi everyone,
I am having a hard time trying to track down an oil leak on my 7mGTE. So far I have replaced:
CPS O-ring
Cam cover gaskets
Oil Pressure sender
Cam shaft oil seals
Oil Cooler Lines
I have still got a fairly bad oil leak leaving a puddle of oil about 6cm across after leaving the car overnight. Is there anywhere else on the hot side of the engine I have missed? All the oil seems to be collecting around the rack then dripping from there.
Any help would be greatly appreciated
Thanks
Matt
CPS O-ring
Cam cover gaskets
Oil Pressure sender
Cam shaft oil seals
Oil Cooler Lines
Thanks
Matt
