Oil leak from the bottom end.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
I have an oil leak from the bottom end. It looks like it may be comming from the lower timing case behind the crank pulley. I accidentally clogged the PCV system and blew this seal and a cam seal. I also forgot to put RTV sealant between the front crankcase and the block when i did the headgasket. I used brake quiet, but I'm not so certain this is where the leak is comming from. Is it the front main seal or is it the crank pulley seal?.. or are those the same thing? Could it be anything else? Let me know what you think the cause is based on me messing up with the PCV.
Front Main is the crank seal and brake quiet should have been fine!
You may have pressured the seal enough to either pop it out or roll the lip under.
(my guess would be it's popped out if it was installed dry)
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
I think thats what it is too, thanks IJ! The crankseal is similar in design to the camseal? right? Because thats what happened to the camseal.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
wow, what a day. removing both the crank pulley and the timing gear took some effort. I destoryed the little "walls" on the timing belt gear BTW. The crank seal came out in about 20 seconds with my pink screwdriver, so I'm like 99% possitive thats where the leak was comming from, but you don't think its likely that the leak could have come from behind the oil pump gear (IJ, lol)?
When you replace the seals smear some permatex #4 on the outside of the seal make sure the case is spottlessly clean (paint thinner works well for this)
Then smear some grease around the inner lip of the seal and reinstall!
This helps the seals slip into place with minimum pressure and when the permatex sets it helps stop them popping out again.
