oil in timing belt case
CHRIS EICHMAN
26
moreno valley ca
ive got oil in the timing belt case and also on both sides of the front of the motor. I just put it together. New seals and gaskets. Iam in the process of pulling the front covers off. if anyone knows a common reason this occurs please let me know. meanwhile i will be checking seals and gaskets. Any thoughts would be welcome.
MA70witBoost
Registered Drifter
^ what they said... Only two seals on the lower half of the motor that might alow oil behind the front engine cover where the timing belt is housed would be the front crankshaft seal and the oil pump drive seal. I can't think of much else. Take off the front cover, have a can or two of brakleen handy and see what ya got.
92nsx
2,957
Clearwater, MN
Cam seals, I only say this because mine also leaked, opps I mean my builder forgot to install them all together!!!!!!!
cam seals, headgasket, aux shaft (for the oil pump), front main... think if they didn't apply FIPG on the front cam caps it would leak as well...
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
What Poodles said, plus one more. There's a gasket between the rear timing cover and the block itself.
There are also a couple plugs that connect to high pressure oil galleries IIRC, any one of those missing would make for mayhem on a large scale.
