oil IN cylinder
bennza
Houston
So i think i have a big problem. I have searched the forum for while and i couldn't find a clear answer for my problem. There is no oil in my spark plug valley or in the spark plug chamber. The oil is inside the cylinder and all over the tip of the spark plug. But only in my 6th cylinder the one nearest to the firewall. So where is the oil coming from my temps and oil pressure are fine according to my dash. doesn't seem like the oil is coming from the valve covers. has anyone had a similar problem?
Oh and my car doesnt misfire takes a bit longer to start but always starts fine.
Idles differently some days it idles at 600-700 where it should be but some times it idles around 1000.
valve stem seals or a bhg. most bhg's will tend to either just blow on the 6th cyl or more.
comp test and block test. if both come back fine replace the valve stem seals.
bennza
Houston
thanks for the tips man. Hopefully its not a bhg it got done around 4 yrs ago but with a stock hg and torqued stock. But who knows it a possibility. I never even thought about the valve stems thanks
