every time i take off the turbo inlet accordion hose i always find like 3 drops of oil sitting right their in front of the turbo entrance so i fallowed the oil and im sure its coming from both breather holes on the top of the valve cover, and also its been going threw the other pipe that it connects to into the throttle, so i took a look in side and sure enough it was black in side the intake manifold. so i took it out to clean it and of what i could see the valves are looking good. so would could it be? where could the oil be coming from?
if it helps its a 1990 7mgte
