Oil filter question
Mr. Y
80 miles away from Kremlin
Hello!
I ordered summit oil filter relocation kit. It uses Ford-style filter (3/4-16"). But there is one problem - we do not have American Fords in Russia. So we haven't filters for it.
Tell me please mark and model of viechle which filter I can use with summit kit. Or maybe part numbers according Mahn or Knecht catalogues.
PS: I think I can find filter that fits Ford-style adapter, but will it be good enough for Turbo Supra? That's why I ask some prooven filters...
turbogate
Life is Boost
May 18, 2005
425
South, FL
Mr. Y said:
Hello!
Someone correct if I'm wrong. Mr Y, I believe Toyota uses also a Ford filter type which only means that the ford and toyota use the same filter threads (3/4-16) and the size of the area that connects to the adaptor. I ordered the same relocation kit from summit, and I'm running it with the Toyota filter. give me the summit part number for the kit so I can confirm we have the same one. Now you might want to double check that the supras in your area (non nato) didn't use a different thread filters etc. but I doubt it.
Mr. Y
Well, I don't have kit yet (long-long shipping), but if Toyota Filter will fit it - it will be very good. I always use original toyota filters and haven't problems with buying 'em.
turbogate
Life is Boost
May 18, 2005
425
South, FL
If you use Summits website to track your shipment, you can find the part number. I just wanted to make sure we have the same kit.
This is the one I ordered
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM-G4985&N=700+0&autoview=sku
You can double check your order here:
http://store.summitracing.com/eru/
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Privet Mr Y...kak dela? Ya govoru nemonoga, no ne ochen xorosho ;).
Most Toyotas have been using 3/4-16 filter studs for a very long time. Any mount with such a stud will take a Toyota filter but there are better filters to be had. You can cross reference a Mann filter on their website:
http://tinyurl.com/2tpg9v
I'm fond of the W 719/5 for Toyota use but be aware the bypass valve has a higher setting than typical Toyota filters. Ydachi...
