did you just reuse the stock lines, but added some to lengthen them?jdub said:Yep... Long Tru-Cool 11" x 7.5" x 1.5"
Posted pics here...3rd page at the top.
http://www.supramania.com/forums/showthread.php?t=2245
IJ. said:A FullFlow Cooler with a T Stat gives great results on our motors.
IJ. said:The idea of the T Stat is so you're not cooling the Oil when it's cold.
This will only work on a Full Flow system where ALL the Oil goes through the T Stat/Cooler not a bypass cooler like the stock system.
jdub said:Use of a T Stat is the best way to flow your oil through a cooler.
I chose the Tru-Cool because it is a self regulating bar & plate cooler. When oil is cold it is viscous. The Tru-Cool design allows the colder, thicker oil to flow efficiently through two open bypass channels positioned at the top of the cooler. As operating temperatures increase, the oil becomes hotter and thinner. It is then directed through the core where it is cooled.
Not as good as IJ's set-up, but seems to be working well for me.
