Oil Cooler?
Is just the cooler or the kit? The kit prolly isn't worth it.
Should read te full flow oil cooler system sticky in the oil section.
You can did cheap cookers on amazon.com. I will be using a big cxracing one. Can use push lock hose and fittings from summit using summit fittings for pretty cheap. Along with summit hose. Best to stay away fro
Ss hose for the oil system incase it rubs and sparks.
Not worth it at all. You coudl get all that from summitracing.com or amazon.com for far cheaper. Plus its got the fittings already on the hoses from the looks of it. Better to just make your own from sctrach. And use a thermostat.
Push lock fittings.
http://www.summitracing.com/search/...ee/Fitting-Style/Socketless-barb/?Ns=Rank|Asc
twist tite hose from summit
http://www.summitracing.com/search/Part-Type/AN-Hose/?keyword=twist+tite+hose
or if you want stainless or nylon braid hose.
http://www.summitracing.com/search/Part-Type/AN-Hose/Brand/Summit-Racing/?Ns=Rank|Asc
http://www.summitracing.com/search/...ttings-Plugs/Part-Type/Hose-Ends/?Ns=Rank|Asc
Good t stat and bolts to the block
http://www.summitracing.com/parts/EAR-502ERL/
Better stat and you have to run adapter on the block and then to this and then to remote mount oil filter and cooler.
http://www.racerpartswholesale.com/category/Remote_Oil_Thermostats
oil filter adpaters for the mocal( i have canton($) ones)
http://www.summitracing.com/search/...word=oil+filter+adapter&kr=oil+filter+adapter
oil coolers.
http://www.amazon.com/Black-Cooler-.../ref=sr_1_106?ie=UTF8&qid=1314845023&sr=8-106
http://www.amazon.com/s/ref=nb_sb_n...ds=cxracing+oil+cooler&ie=UTF8&qid=1314845018
Use -10an. Build your own with a thermostat so it fits properly and doesnt just push cold oil through the motor when the engine is hot and oil is cold and ruin the oil and possibly your motor.
