Alright guys I just finished putting my engine back together. I had some head work done, installed 1.2mm cometic hg, arp head bolts, timing belt and all of the other little things.Anyways, I started to pour the oil in and 3 quarts through I heard some dripping, it was coming out between the head and the block on the intake manifold side towards the front, maybe the 2nd bolt. Then I realized it was also leaking from the exhaust manifold side towards the back. I torqued the bolts to 85 lbs.I dont have any idea what could of happened. I need some help and thanks in advance.:wtc:
