oil catch can
bobiseverywhere
bobb'n for money
Montreal
www.bobiseverywhere.com
I have one now but i realized that it's leaking air
There is a clear plastic tube on one side to see the level in it but where the tube connects to the can you can here the vacuum leak and i am sure boost leak as well.
Whats would be the best stuff to use to plug it up?
bobiseverywhere
bobb'n for money
Montreal
oh i have a 1J now Ian
there is a PCV valve off of the cam covers that goes to the intake manifold
Aaron at drift motion said that would be where i would want the catch can. So now i am guessing i should move it to the other location on the other side?
there is another one going from the exhaust cam cover to the intake tubing before the turbos. Should both be routed to a catch can or just the other one? none?
Josh: Sorry not familiar with the JZ routing but I stand by what I said the CC should NEVER see boost pressure!
So should be Cam Cover/s> CC> inlet between turbo and filter
