Mrbaboon said:
I always thought that while under boost you would get vacuum from the accordion hose, due to the turbo pulling the air.
Look at how it's setup. Why would there be low pressure on that port unless the air filter was restricted? The pressure drop across the filter and AFM are minuscule (you want them to be) and the PCV port isn't near enough to the turbo to be affected at anything but full boost. Besides, why would you want a negative pressure in the accordion? Isn't that why you guys put bigger pipes and those (supposedly) high performance air filters on? To avoid that sort of thing? Try measuring pressure drop along your induction system sometime. How do you think I know K&N filters don't do anything except suck in dirt?
For all intents and purposes the air filter and PCV port are the same point pressure-wise as long everything upstream of the PCV inlet is free flowing. Unless you've got a garbage bag around your air filter there's maybe a tenth of an inch of water at the PCV port and that's from the effect of the air rushing past it. Think of blowing across the top of a bottle. It doesn't amount to squat. It's true the port goes negative under full boost but it isn't much and exists only because of the restriction posed by the air filter, box, and AFM. But hey, don't take my word for it. Use a manometer and see.
Finally, how often is the engine under boost compared to otherwise? By disconnecting the TB port you're depriving the engine of PCV where it spends most of it's time. Fwiw I've yet to see a catch can plumbed right. It's because many people don't fully understand how the PCV system works.
