oil catch can condensing water?
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
hey guys,
put my driftmotion catch can on about a week ago on a fresh rebuild and had it hooked up correctly:
7mge
took the "t" piece off of the valve covers and turned it backwards to face the cabin, then ran 3/8" fuel line to the catch can mounted beside the charcoal canister. i sealed the catch can at all locations with thicker o-rings and fipg, and had stainless steel scrubbing pads in the can. i ran the line back into the TB.
after running this a week, i checked my oil (full on the start) and noticed it was about a half quart low. took the catch can off to see if there was a half-quart of oil in there but upon tipping it bottom up, a teaspoon of water ran out and that was it.
i took the can back off and returned it to stock and havent had oil level problems since. i did clean the "t" pipe out and it was a little dirty but it wasn't plugged.
could i not be pulling enough of a vacuum to keep the oil in the crank seals, and it was leaking out the back?
Clip
Oct 16, 2005
2,738
9
Virginia
Davismj711;1145389 said:
Clip
I used a Mckinney Racing CC. I am getting the same, water, or condensation, after a rebuild. I do not know if it is the norm, but I believe it is.
Until we get some blowby many miles down the road I hope, I would think thats all we will see in there.
i like the idea of keeping my intake manifold clean, i had to spend hours getting oil out of it during the rebuild.
jdub
Feb 10, 2006
10,730
Valley of the Sun
The water is a combustion by-product. It and the hydrocarbon by-products the motor produces is the whole point of the PCV system...they are drawn to the intake manifold and burned. Your catch can is condensing the water vapor...it's normal ;)
Clip
Oct 16, 2005
2,738
9
Virginia
if the "t" is clogged, what effect would it have (on the vacuum) on the TB? would that make me lose oil pretty quick?
lagged
1991 1JZ
new rochelle
how MUCH water you are seeing is a concern.
if its just a SLIGHT amount of condensation, its probably fine. but if you start seeing the classic oil milkshake in your PCV lines or under the oil cap then you are in for some trouble.
Depends a lot on how much you drive as well. The water is the reason short trips are bad for your oil as the oil doesn't get hot enough to boil the water off (that mixes with other combustion gasses and makes acid)
lagged
1991 1JZ
new rochelle
personally id say seeing any water condensate is bad but i dont want to be an alarmist. i have been told its normal to see it from time to time and i can see why that is true.
the only time i have any had any kind of water in my PCV lines was when i blew my head gasket.
so as usual, YMMV.
Clip
Oct 16, 2005
2,738
9
Virginia
so whats the deal on the oil disappearing? just a fluke or will it blow out seals if the vac isnt good enough?
jdub
Feb 10, 2006
10,730
Valley of the Sun
The 7M-GTE always uses *some* oil...it's the nature of the beast. On a new motor, the rings have to fully seat...it will use oil until it does. What oil was in it for break-in and have you changed it since the initial fill?
BTW - a tea spoon of water is not excessive.
Davismj711
PA Mountain Supra
Shaeff
Thanks in large part to your advice. Many Thanks
Lagged
I don't know if your becoming an alarmist, but it doesn't take much to sound the horn of a BHG with our Supras.
That being said I would submit that if you purchase a well designed CC you are in fact going to see some water condensation. The desgn allows for the heavier particles in the PCV line to drop from the current air flow. There is also a drop in temperature if the CC is mounted as far from engine heat as is realistic. The cooler area will precipitate this condensation.
I would think that such a small amount spread through the lines themselves would be either, never collected,(Due to raised temperatures throughout the lines), or unoticeable.
You may also SEE a milkshake within a CC if you have some blowby that is collected along with the condensated water.
Cheers
Davismj711
PA Mountain Supra
j3pc
I would say that the crankshaft and other moving parts serve as the "shake" part of the Milkshake. If left to sit in a container the coolant will separate from the oil.
So you are correct, there would not be a "Milkshake" look inside the CC, just some of the ingredients. My bad, I will blame that error on a senior moment ^^
Clip
Oct 16, 2005
2,738
9
Virginia
its a 7mge, i've used sae 30 for the first 500 miles (changed at 20, 250) then switched to castrol gtx 10w30. once i get to 1500 (about 400 miles away) ill switch to german castrol.
jdub
Feb 10, 2006
10,730
Valley of the Sun
You're just getting the engine broke in...a bit of blow-by is normal. That explains the water you saw in the catch can. Same for the oil consumption...it should fall significantly in the next 1000 miles or so.
