PorterzSupra said:ohh im a retard... srry.
One more thing, can I tee onto the "oil cooler" lines for turbo oil in and turbo return, since im using a NA block there are no other oil in and out lines in the block but I could use the turbo oil filter adaptor and plug in the pan I can make it work
Also the position of the oil pan drain hole is different on the NA, will I still be able to get to the oil drain if I use it in a turbo body?
NoPorterzSupra said:ohh im a retard... srry.
