odd smoking pattern
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
pretty much, my car smokes....
After I let the car warm up, and get on it for the first time, the car makes a fairly good ammount of smoke, but never does it again until I turn it off, let it cool, and then drive it again.... is this normal? exhaust = bic dp w/ a 3" muffler bolted to it (exhaust stops under passenger)
Supraholics
.928 RWHP & Climing!
Apr 1, 2006
1,577
PA
www.supraholics.com
I have the same problem with my Cressida.
http://www.supramania.com/forums/showthread.php?t=31752
My issue is that the turbo is leaking oil, mostly at the inducer, so the oil is air forced into the intake and then burned in the cylinders. Or at least that's what I think it is since the car did not smoke before I turbo'ed the car. If you take your IC piping and find oil spots, then that's probably your issue as well.
bo3232000
Lurking in the dark
Jul 22, 2005
57
Cumming,Georgia
3rdtimearound said:
Could be valve stem seals
Wayne
Hate to say it but the turbo seals are starting to take a shit....Find out the answer and just pull the lower intercooler line off at the turbo and wallah oil or not....If not you need to do a good intake cleaning on it,there may be oil built up in the grooves of the accordian hose,and it sucks thru after you jump on it....Valve stem seals always load oil into the cylinders after shut down and drip down the stems,doubt they are bad.....Overall it is probley not that bad since valve stem seals are FTW to do with the head on the car and CT-26's are still pretty abundant....
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
bo3232000 said:
Hate to say it but the turbo seals are starting to take a shit....Find out the answer and just pull the lower intercooler line off at the turbo and wallah oil or not....If not you need to do a good intake cleaning on it,there may be oil built up in the grooves of the accordian hose,and it sucks thru after you jump on it....Valve stem seals always load oil into the cylinders after shut down and drip down the stems,doubt they are bad.....Overall it is probley not that bad sice valve stem seals are FTW to do with the head on the car and CT-26's are still pretty abundant....
thanks for the good info... i figured it was the turbo, but thought i'd get some valuable input.... just means it's time for an upgrade :D... valve stems were done not long ago (3,000 miles)
SPD TRP
Formerly 3rdtimearound
Apr 12, 2005
526
Katy Texas
My bad, thoght I read that it smoked bad in the morning and after it would sit for a while on start up. Went back and read it again with my glasses. lol
Wayne
