I have an odd question, my 7MGE (from a 90 Cressida) is being put onto an engine stand for me to redo the seals, etc..
Now, its a 1000 lb engine stand on wheels, and has a 4 pt connection system (kind of an "H" configuration). If it would help, I can post a pic up, but I think someone here will know the correct answer anyway...
I have the stand attached, but had to use different bolts because I dont have the bell housing bolts (the other engine is still in the 87 MKIII). However, if I lower the engine hoist, it seems to be a tad top heavy and I think it will bend the 4 attached arms.
So.. for those of you who have done this, where is the best 4 points to locate the bolts, and what bolts are used (I am assuming the are 17 mm for the bellhousing.. and am about to go to the TSRM). The engine is very front/top heavy and I want to make sure it doesnt bend the arms or tip, plus I will be spinning it once I get everything off except the head.
Thanks in advance! : )
Edited to add: I cant see what the bell housing bolt is (it has numbers.. 375 (27,37) but I dont know what they refer to). If its typical Toyota, its going to be a 17 mm and approximately 3-4" long I am guessing. (that might be too long).
I will have to get those bolts, so I may just order new ones just for giggles... doubt I have ones that will match properly with thread.. most of mine are not metric..
