jdub;1145334 said:
Grim - are you using the stock nuts? Were they previously used?
I'm using ARP 12 pt nuts on stock studs...the head was helicoiled. A proper helicoil is stronger than the threads in aluminum...regardless of stud size.
The studs should be seated finger tight against the head before the nut is screwed on/torqued.
reused the stock nuts and studs.
you sir have some nice $5 nuts, i actually called arp today hoping for some good knowledge on studs and what i should expect. They didnt care to much once i told them they weren't arp studs.
all were finger tight before torquing.
Little info to make the picture more detailed: After the 1st 50 miles, all needed a little torquing (1/8-1/4 turn MAX). Checked them again after another 50 miles or so and a few needed less then 1/8 turn except last one on the back of the head (#7?). It needed a good 1/8 of a turn. Checked them again and all are good except that damn #7, another 1/8 turn or so.
****pulled it out, helicoil and threads are perfect, hopefully new hardware will solve it****
