Occasional backfiring in between shifts
Backlash2032
1,823
Nebraska
So there's one fault with the GTE swap so far. It likes to backfire inbetween shifts. I thought it would be the TPS out of adjustment, so I pulled the codes, no 51. Ohmed out the TPS, with no shim there was resistance, same with a .5mm shim, and then infinite with the .9mm shim. I double and triple checked this.
Then I noticed that the dashpot diaphragm thing that screws to the throttle body was loose, so I tightened that up, and adjusted the dashpot. Having no tach (since its still an N/A tach), I just tried to mimic my old N/A throttle bodies dashpot movement. If that makes sense.
So I took it out for a drive, and everything seems normal. Then I hit boost a little (no where near WOT) and I go to shift and whaddya know.. It backfires. I have no idea what could be causing it to run rich inbetween shifts. Completely bone stock where it matters (stock AFM, stock turbo, stock bov whatever. The only aftermarket parts are the pistons (NPRs) and the headgasket (Titan MHG)). It never did this when I had my TPS disconnected due to it not working (before I replaced it).. Could it be another bad TPS?
te72
Classifieds Moderator
6,607
4
WHYoming
Well, I've never known a stock electronic 7m to NOT backfire when you stick an exhaust on it, so I wouldn't worry about it much. Are you running a catalytic converter?
The turbo cars like to run rich, particularly when you run a BOV to atmosphere, but if you have the stock BOV...
Sep 19, 2011
510
Des Moines, IA
Mine runs real lean around 3500 right as I am going into boost, and I try to take it easy until I can get a proper tuning screw in (tomorrow when I get it back). I back fire quite often, and it is a lean back fire not rich, as I have a wideband and it is reading real lean.
Backlash2032
1,823
Nebraska
No I don't have a wideband.. But I mean I could understand a little gurgle or two.. But this is like I just shot a rifle. And for the record I'm running open DP WITH the factory cat in the DP.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
People are always so quick top blame the EFI system when it's usually not at fault. It's not your TPS. And are we talking real backfire here or after-fire?
Edit: Never mind. I see you have an open DP...
BrandonW
1,300
N.J.
every now and then i get a nice "pop" from the exhaust but its because i run rich between shifts with the vented bov
Backlash2032
1,823
Nebraska
I think I may have found the problem. The EGR pipe that goes to the plenum was not connected to the EGR. Granted, the EGR isn't hooked up either but that's just a giant un-metered air leak. I have yet to drive it after fixing this, but I have a feeling this was my problem.
91whitepack
71
slidell, louisiana
Mine has always done this. Even before I installed my atmospheric blow off valve. If I bring it right where it gets over zero and granny shift it will shoot a flame Everytime.
Skeezix
Supradope
Dec 30, 2009
229
Regina, SK
My car after-fires quite often but not every time. Its just the combo I have, stock ECU, atmospheric BOV, BIC DDP. Timing is bang fuckin on too. If you put a muffler or some more exhaust on it might quite it down or not let it happen at all.
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
Mine does this as well. Stock JDM ECU, no EGR, 3" turbo back Raptor Racing exhaust, open element filter, Bosch BPV (recirculated), Stock timting, TPS is good, etc, etc...
My wideband shows I'm around 14.5 until I'm WOT or into boost. At that point it will slowly go richer until it hits about 11.5 or so. To me, that seems perfectly normal, so I'm not sure why it pops so much.
Backlash2032
1,823
Nebraska
Anybody have any ideas to this? I find it hard to believe that Toyota's flagship gt car afterfires normally...
Sent from my ADR6425LVW using Tapatalk 2
Skeezix
Supradope
Dec 30, 2009
229
Regina, SK
Why? It only makes sense being tuned pig rich from the factory, and then you opened the exhaust...
