has any one used the OBX cam gears? if so, what are the good parts about it(if any) and what are the bad things about it.
IwantMKIII;977906 said:aluminum was not hardened enough and the holes for the pins on the cams widened causing knock
when i did this vid i thought it was actually rod knock...
jdub;978087 said:I remember that one![]()
super supra dave;978072 said:so should i re-ebay these cam gears and go with some AEM cam gears or is there anything i can do to make the OBX work and to make that nosie?
arizzle;978795 said:ive ordered a set and they didnt fit properly!!! not worth it just buy some real stuff =D
