Can anyone tell me if these codes are correct and what I need to do to fix the problem? I got a code 32 Air flow meter or vaccume sensor signal fault ....51 AC signal on... any help will be appreciated thanks.
yea mine is a pre-'89 but it was an NA so does that mean it doesn't have the HAC sensor since its not built into the harness? the harness is off a pre-'89 also and i read only the GTE had the HAC sensors soooo?
