O2 sensor 3 wire or 1 wire?
mk3supreme
Hoes Anyone?
Jun 27, 2005
69
Los Angeles
Guys My Supra has a three wire o2 sensor it's the one that was on the car when I bought it. But when I go to the parts store they only have the 1 wire can I still use it? and is the 3 wire stock?
kamil
87T Targa
Apr 4, 2005
144
Tucson, AZ
I'd be curious to see if it made much of a difference, the computer doesn't use the NB o2 input when the engine is cold anyway does it?
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Computer will whine and complain if you try to use a single wire sensor. Get a 3 wire - even if you have to splice it into the wiring harness manually.
Last I checked, MDCMotorsports on here had a shitload of stock O2 sensors for sale pretty damn cheap.
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
Followup post - I've heard that the computer doesn't care about the other two wires, and I've heard that it does. Chances are I'm going to test both scenarios soon, and I'll let you know the results.
Supra5MGTE
421
Tampa, FL
I would only use 3 or 4 wire O2 sensors. 1 wire is OLD SCHOOL. you NEED/WANT the heater. Especially if the car has it stock. I got a 4 wire NTK sensor new off Ebay for like $25 shipped. My old 80's Corvette has a 1 wire Peice on it... I upgraded to a 4 wire and it was much better.
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
The reason I'm researching this is because I'm replacing the stock O2 with a wideband, and the output from the wideband to the ECU is only a single wire.
So, the question then is, do we just leave the heater wires disconnected, or do we need to wire in a resistor, or do we need to do something else?
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Ok Grim, I suppose one more won't hurt.
Th ecu controls the O2 sensor heater but does not monitor it. No code will be set if the heater become open although the sensor will become sluggish and will fall out of closed loop at idle and take longer to warm when cold.
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
JJ, you are the whole reason I'm going to try it this way - before I read some of your posts on this subject, I was under the impression that the ECU monitored the heater circuit! :)
I'm not concerned about falling out of closed loop, as I'll be feeding the signal from a wideband whenever the heater circut isn't hooked up - when I have the wideband out of the car, the heater circut will be plugged into a stock O2 sensor as normal.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Keep in mind what I'm telling you applies to what I know of the 87-88 ecus. I'm not certain if monitoring is done in the later computers but fwiw my TCCS books don't mention it. As far as I know heater power is simply supplied via the EFI Main Relay and the ecu provides a full time ground path for the heater after engine start.
I can tell you for sure that on my 87T sensor heater voltage remains fairly constant (although current varies as heater resistance changes) and an open in the heater circuit will not set any codes. Nor am I aware of any TCCS OBD-I codes related to heater failure. It's common with OBD-II however.
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
Update!
I have discovered that the later ECUs must be slightly different. I wired in my ZT2 wideband, and used the narrowband sim output to drive the stock ECU's O2 sensor input.
I left the heater element leads from the original O2 plug disconnected. The ECU promptly threw a code 21, O2 sensor dying.
So, I wired in a 1000 ohm resistor across the leads for the heater... and the code went away instantly. :)
