Well got rid of the pos. Pulled all of my electronics out to do my swap into a cressida .
Then i found a 88 supra hard top turbo 5 speed that had blown the hg. so the x owner put a so called jdm motor in it and it has set for 5 years cus he did not know what the hell he was doing but was smart enough to drain the gas out of the tank before he let it set. So on to my questions im pulling a 51 code which is noting. After 3 ecus i know that's not it . The tps has been rigged so im pretty sure thats the reason for that coed.
Im not getting any fuel. checked the fuel lines and the fuel pump. fuel pump sounds
like its working fine after we jumped it at the dig box. so is it my filter or the fuel pump filter bad? i plan on replacing both. also can i torque the stock head down with stock hg and get away with it for awhile? plan on torquing it down to 85ps is that right?
i will post pics soon.:naughty:
