Does anyone know if a npc air fuel ratio gauge with o2 plug off a cobalt SS turbocharged work on a mk3 supra 7mgte I will probably just have to change o2 right
But in order to get an accurate wideband reading you need the wb02 sensor which is screw in style. Will need to get a bung and have it welded in on your down pipe if it doesn't have or already.
Great choice, I'm currently running an AEM. It works great, and the install is easy.
One feature I really like is how you can match it to your interior as it comes with both black and white gauge faces, 2 different bezels, and 7 color LED lighting.
-AM3
