Not to sure what this light means?
86.5 MKIII
7
Port Alice
Just found out it's the engine temp gauge. Mine is acting up because my temp is fine doesn't go past half and only when i corner hard right or left and go over bumps in the road does it go on. It doesn't stay on just a flicker, just been wonderin whats up with it. My oil level is fine as well.
Supra
304
Rockford, IL
ValgeKotkas said:
LOL that's so wrong.... The far left light is not a temprature warning indicator.
It only indicates that your coolant level is low in the reservoir (?sp). Of course low coolant level indicates coolant consumption, which means coolant leak which means you need to post several more times about "blown head gasket". Then go fix the cracked, broken coolant hose or radiator cap.
Oh, and fill your coolant bottle behind the bumper to turn out said light.
86.5 MKIII
7
Port Alice
ok so it's coolant level....tyvm....it's not coolant consumption.... the guy i just bought the car off of just put new rad in right before i bought it....oil is fine. He just may have not put enough coolant in is all.
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
ValgeKotkas
2,224
Over the pond
Why the heck does the manual say so then?
