Not the usual waterfall sound....
rakkasan
Currahee!!
Fort Campbell, KY
but what the hell causes a bubbling/sucking sound located behind the glovebox? It has to be something to do with the AC/heater as it's only heard when I first turn the AC/heater on or when I change the temp.
rakkasan
Currahee!!
Fort Campbell, KY
I'm fairly certain that it's not air in the heater core / coolant lines. I've alrady had the waterfall sound.
How many servos are there in the air mix box? Did you had the same problem?
Thanks fellas
rakkasan
Currahee!!
Fort Campbell, KY
would a bad heater core have anything to do with it? I've been searching the issue & came across the bad heater core symptoms (oily windshield), which I have.
Bueller? Bueller?
mrnickleye
Love My Daily Driver !
Jun 8, 2005
825
Mojave Desert, Ca
Have the cooling system pressure tested. If the heater core is leaking it will show up, as with any other leaks. Gurgle sound IS air in the core. I took the toggle off the thermostat, drilled the hole to 5mm, the system burped itself free of air in 3-4 days. BUT....if it returns....probably a BHG.
rakkasan
Currahee!!
Fort Campbell, KY
Even though I have no coolant loss, no leaks, no BHG, I've decided that the heater core is on its' way out based on all of the symptoms others have had (matching to a T). For now I'm going to bypass it (I live in Florida).
The problem only occurs when you first start the A/C, or when you change the temp setting, so I really believe it's the air mix box. I'm hoping someone has fixed / replaced on & can give me some info about how to do it.
mrnickleye
Jun 8, 2005
825
Mojave Desert, Ca
Thats a weird one. Florida=humidity. Is the drain hose for the a/c evaporator box plugged? It comes out thru the firewall at passenger foot area in engine compartment. I've seen several plugged. Condensed water will get trapped in the box and slosh around and make some gurgle sounds.
shaeff
Kurt is FTMFW x2!!!!
10
Around
he said he has an oily residue on his windshield. thats the heater core :( its not as bad of a job as everyone makes it out to be.
-shaeff
rakkasan
Currahee!!
Fort Campbell, KY
-shaeff
It's amazing what you can solve by using the search feature. I couldn't figure out why I couldn't keep my windshield clean. :icon_sad:
shaeff
10
Around
rakkasan said:
It's amazing what you can solve be using the search feature. I couldn't figure out why I couldn't keep my windshield clean. :icon_sad:
i know! i couldnt figure it out for almost a year when i first got my car. haha, i guess i kindof owned myself :( ah well, it's all fixed now! good luck!
-shaeff
