while replacing the head gasket i ran across this. not sure if this is how it should be, it doesn't look to be correct. im not sure where this would have went.
No, it's capped on LHD cars. Later models used a different pipe assembly that goes around the block for RHD/LHD (eliminating the cap that tends to rot and fail), early cars use the same part.
