okay so last year i dropped usdm 7mgte into my 88 non turbo. had some problems with cooling and other leaks, now ive got the worlds biggest boost leak and a warped head (compression test shows 150psi first two and last two cylinders, middle two are 120psi)
so now i learnt my lesson about doing things half-assed and the cheap way costs more time and money in the end. ive decided to cheat and go with a jdm 2jz this summer. seems like everyone else is doing it, so a lot of more info and suggestions are out there.
here is my progress so far of my custom parts i know will not fail this time:
use to be cruise control and fog switches here
apexi avc-r boost controller fitted with body filler
i positioned it on a very small angle so i could see it better from driver's seat
primed and painted waiting for vinyl
batt relocate
same cf vinyl will be used on apexi dash
custom fan shroud w/ electric fans mounted to fluidyne rad bought from raptor racing
batt relocate
