http://mk3ukr-supra.net/Brakes.htm
I've read a few threads about people using the GTR R33 Brembo front brakes off of skylines for the MKIII's front brakes. I think this is great with the combination of evo rear brembo calipers you can now have a matching set of brembos for our mk3's for as much as a wilwood front BBK. I know it's not going to be better then that set-up but to change from single pot calipers to 2 or 4 pot on a budget is great. my problem is I can find all the info I need about the evo rear's but nothing about the skyline front's. Do you still need the cobra bracket kit? I'm pretty sure the cobra rotor is compatible. But by the sounds of it something has to be done for the caliper to fit all the way over the rotor. Trimming the dust hat is easy but I'm worried about anything needing machining. I'd like to have all the spec's before I invest. I'm not trying to take away from what people are doing for the community, but I do enjoy a bit of a DIY challenge and it fascinates me using parts off other vehicles and making them compatible for mine.
