Okay so Because my car was puffing white smoke once in a while and Would smoke black sometimes I thought BHG for sure so I bit the bullet and took it in 4 Diag. Turns out I have oil leak in my Turbo return hose gasket and coolant leak in my Throttle body somewhere which is the white smoke. They also said my car was idling on 5 cylinders. I pulled the plugs and Cyl 5 is Black as hell. My mechanic friend told me it could be because it is untuned (SAFC is untuned) and I have the Lex/550 mod. I also hit abnormally low fuel cut. The engine does not shake AT ALL at idle. But something is obviously up with cyl 5, could it be an overfuel problem caused by untuned safc?
