normal afr?
zigspeed10
31
ohio
I know the answer is here but I couldn't find it in my search. I have a wideband o2 and at about 5000 rpm and above my afr's go to 10.1-10.2 and I've seen it hit 9.9. This seems rich to me. Normal cruising afr's are 14.7-14.8, Cruising Vf is mostly at 2.75V. Only mods are 3in. turbo back and bosch bov. My question is are these normal afr's? or do I have a problem somewhere. Thanks
zigspeed10
31
ohio
maybe my question should be what afr's will a stock car see at WOT and higher rpm. I just want to make sure I don't have any boost leaks, or sensor, or injector problems causing my car to run rich. Thanks
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
That all sounds about normal. The stock setup runs rich...which is safe.
No problem that I see, don't worry about it.
Slow_Sc3
I beat bikes dude
Apr 2, 2005
401
Maryland
suprafanatic said:
i thought 10's and 9's were on the leaner side?
you sir are wrong
thechori said:
i think 9-10 would be on the rich side, 18 is very lean IIRC
correct
your cruising A/F is perfect but you can take some fuel out at that 5000rpm point you want to be closer to 11.8-12.0ish
