Noobie question.
HommerSimpson
1,067
New Smyrna Beach Florida
MaJiKaL TaNk;1005114 said:
I'm not trying to sound stupid or anything but what exactly is the difference between a normal downpipe and a divorced downpipe? I mean is there really any benefit?
I'm gonna continue looking around to see the advantage and stuff but any opinions or info will be appreciated.
I think what they mean is the waste gate pipe is open... ? not 100%
mkiiSupraMan18
Needs a new username...
United States
real quick search. linked to BIC's site....
"3" Downpipe with Divorced Wastegate (DDP)
This specially designed full 3" downpipe utilizes a seperate pipe for the wastegate exhaust that vents to the atmosphere, making for less turbulence and higher flow for more power gains. Dyno results have shown gains of 29 whp over a standard 3 inch downpipe setup. Warning: Running the wastegate straight to the atmosphere makes your car LOUD at full boost.
As with all my downpipes, this eliminates the stock heavy restrictive turbo elbow. It has 3/8" thick flanges and bolts to the CT26 turbo and up to the stock or replacement main cat. This downpipe will increase throttle response and the turbo will spool much quicker than stock and will make 13psi at 2600-2800 rpm, and keeps pulling hard up to redline. Made from mandrel bent aluminized steel and coated with VHT high temp paint. Includes a new gasket and bolts for the catylic converter flange. Uses the stock O2 sensor and heat shield.
*NOTE The pictures shown here are with the optional polished ceramic coating*
*Please allow 3-4 weeks for build time and delivery.
Price $385"
"3" Downpipe
This full 3" downpipe eliminates the stock heavy restrictive turbo elbow. It has 3/8" thick flanges and bolts to the CT26 turbo and up to the stock or replacement main cat. This dp will increase throttle response and the turbo will spool 13psi at 26-2800 rpm, and keeps pulling hard up to redline. Made from mandrel bent aluminized steel and coated with VHT high temp paint. Includes a new gasket and bolts for the catylic converter flange. Uses the stock O2 sensor and heat shield.
Price $294"
"Options for Downpipes
- Re-routed wastegate pipe. Routes the wastgate dump back into the main exhaust for all the benefits of the DDP, but without the excessive noise.
Price $52 (NOTE: This option is only available for divorced downpipes)"
http://www.bicperformance.com/products.htm
*edit*
I linked because I don't know what I'm talking about.
