noob with an 86.5 n/a
bladerj87
salem, or
i have an 86.5 n/a targa with a bhg for the secend time in about 2 months
its so far got only lite mods (short ram intake,stage 2 clutch, Tokico illuminas, and adr wheels)
Mk3_Richard
10
Garage
Welcome!
When you replaced the HG did you use the original head bolts? If so that is your problem. Throw them away and invest in a set of ARP or comparable bolts and torque them a little bit higher than the stock bolts.
A other possible cause is a warped head or short block.
Dunckel
2,949
Spokane, WA
Describe a "little bit higher". Why bolts? Why not studs?
Kckazdude
1,239
Memphis, TN
Welcome!
Why spread the FUD? There is nothing wrong with stock head bolts on the stock 7M. The only problem is improper prep work and torque values.
Also, welcome to the site bladerj87!
Mk3_Richard
10
Garage
There is nothing wrong with studs and I said bolts cause I used them the last time. I torque them at 95 Nm (70 lb/ft)
The stock bolts do stretch a little, and there for should not be reused. There is nothing wrong with them when you replace them by new ones and torque them higher, but here in the Netherlands the stock bolts from the dealer are not much cheaper than a ARP set.
