Hey Guys
Extremely noobish question -->
- is it possible to simply replace my current harness with a stock harness from a 7mgte.
NB:My current harness was custom made by the guy that rebuilt my 7mgte.
- after replacing my solenoids in my transmission I am still having an erratic shift problem and D usually starts me in 3rd gear. Im assuming it has something to do with the way the harness was spliced since this problem only occurred after the rebuild.(harness was created after rebuild)
-i'm unable to get into contact with my mechanic to find out why he had to create a harness if I was merely using my 7mgte(with different internals) with a stock a340e transmission....
- Is it simply a bolt on affair for replacing harnesses ie - find a harness that is for a 7mgte auto and simply plug it in to my ecu
Thanks in advance for any help
