87 1jz car 5 speed
I'm used to the normal supra not starting issue, with the turning of the key the relay clicking and no start. Only reason I'm posting this is because the symptoms differ than the normal symptoms with the issue stated above. Car has been doing it at random. Get in to fire the car up, turn the key nothing at all. The car will toggle power like its supposed to, but will not even click the starter relay. Usually if I sit there for a while it will eventually start, but car has never had the issue in the 2 years I've owned it.
Things I've checked:
Starter relay: tested fine and worked fine
Ignition: tested fine, removed turbo timer and harness in order to remove any aftermarket interference
Clutch switch: took it off and bypassed, not positive if I did it correct. Unplugged switch and ran a jumper wire across both terminals on the plug on the harness side, but after bypass car still would not fire up
Any fuse regarding ignition all started fine
I honestly think its the clutch switch acting funky. If I am correct when the key is turned the only thing feeding power to the starter relay and starting system is the clutch switch. Any Input on the issue would be greatly appreciated. Thanks!
