No Spark.....
kssweeper28
126
Topeka
OK Everyone I had a previous thread titled the Car will not start. But anyways to update to my problem as the title clearly states I am not getting spark. Along with that, my injectors are not pulsing. So maybe its something that will fix the two together. But to give you all some more info on what I have done is the following:
Have great continuity through CPS,ECU Ground,Ignitor,Coil Pack,Injectors.
Although I do not have the 1.40-1.80 resistance at my coil pack. I am reading 0 there. But I have taken a CPS ignitor and coil pack from a running car that I also own so therefore I am going to say the problem probably has to be somewhere in the wiring.
All fuses are good.
No codes,CEL comes on when key is turned to the "ON" position.
Maybe I am in for a new Harness but before I do that I want to double check and make sure that will solve my issues with the car not starting.
Any help would be greatly appreciated as I have now been messing with this same problem for weeks now! AHHH.... THX IN ADVANCE.....
Jspec7m88
1,583
Nappy City
Already mentioned this to you over AIM but I'll say it again.
"I'm still leaning towars wiring." ;)
I hope you figure out exactly what is going on. I know you've been dealing with it for a while now. Good luck.
Jeff
kssweeper28
126
Topeka
Well I do I have continuity from the ECU all the way up to the CPS, but there is not resistance what so ever. But I did just throw in a CPS from a running car that I also own. I have continuity on the ground wires also at the intake mani. Wonder where the problem is......? Any other ideas. Thank you all for the help.
