no spark!
grandmaster
11
Edmonton
I can't get my car to start. I found that I am not getting any spark. I tested the coil resistance as specified in the TSRM as well as the voltage to the coils..all checking out fine. I also checked the resistance on the ignitor. THey were within specs. I had some issues with the 3V test; so I can't varify if it passed or failed this.
Should I just replace the ignitor; or could there be other issues causing the lack of spark?
figgie
Twin Cities, Minnesot-ah
my guess
check the CPS and more specifically the CPS plug. You will more than likely find that it has exposed wire and more than likely two of the wires a shorting out.
grandmaster
11
Edmonton
I'll have to get someone to help me out. I can't tell from inside when trying to start.
If they aren't, what does that indicate?
