no spark to cylinder five two and three
schmall's supe
29
az
i checked the resistance of the coils and the high tension wires but can't figure out whats going. my timing is fine and it wants to start it even gets up to about 1500rpms if i gas it but then dies after about 4 seconds. i just finished my hg job and am so anixous to get it running. What should i do ?/
any advice is much appreciated thank you
pat
skipbarber
2008 Grassroots Challenge
Mar 26, 2008
134
Rockville-ish, Maryland
im assuming youve checked all the wiring to the coils? have you checked for power at the coils? what method did you use to check spark? It's a little odd that youd have 3 plugs missing in a waste spark ignition system...igniter perhaps?
schmall's supe
29
az
i just took a timing light but put it on each wire to each plug. then used a ohmeter to check the coil's the tsrm said that it should be between.3 and.5 when cold but i read .1 off mine . i guess it makes snse two and five are out together cause there on the same coil pack but why three what should i do??
