my RPM guage doesnt work....everything is all hooked up....what can it possibly be? like...what could some of the possibilities be?
i swapped out the entire harness from dash/firewall to headlights from the 89t to the 87 n/a body.....also the dash itself along with the cluster from the other car was placed in as well....YoNkErS87t said:by any chance did you do a na>turbo swap? I see in your profile you have a w58 transmission. If so change the cluster to a turbo cluster or there is a way to change a resistor or some sort in the cluster. It as to do with the different ignition system.
i believe this might be the reason.....b/c everything is worked be4 the swap...yet again i could be wrong....i build motors not wire harnesses and all that technical stuff...(yet):aigo:jdub said:The tach gets its signal from the igniter (turbo motor). You could have a break in the wire.
