No Power to B+
iherduliekme
4
Florida
Hey SM,
I've encountered a problem, and unfortunately I'm not very good with electrical work. I am having a no start issue, because I am not getting power to the fuel pump. The pump itself is fine, but it does not turn on when I jump b+ and Fp. It turns out that b+ is not getting any power, itself. What would cause this? I am in dire straits here. Thanks.
Trnsprtr
25
Stanley, NC
It's been two weeks since you asked, if you still need help on this I'd be checking for continuity between the ignition switch and the check connector and look into replacing the switch if the wiring is OK.
