No oil pressure.
alucardunit1
82
Lee's Summit
When i am driving around its giving me about 20 but when i am idol its like at 2-3. whats going on. my dads guess would be the rings. but any one else had this issue.
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
Rings may, but it would raise crankcase pressure more so than it would oil pressure.
Engine wear is the primary reason for loss of oil pressure. Too much gap between the gear teeth in the oil pump. loose crank/thrust/rod bearing clearances, worn cams, etc. Also low oil level.
How many miles have you put on the engine since you've owned it? Driving style effects wear pattern. My 7M-GE had ~240k on it when I messed it up. I would regularly see 10-15psi hot idle.
Make sure that oil level is at the "full" mark on the dipstick, or even go the generally recommended 1 quart over (for "spirited" driving and hard cornering).
5
Rings wouldn't effect oil pressure at all unless you burn enough oil to run low, or you contaminate the oil enough to lower the viscosity.
alucardunit1
82
Lee's Summit
I have put about 1000 on the car since i got it and its been consistent since i got it even on the highway it rides about 20. lol and when i got the car like 2 weeks ago i added a quart in. and yes for spirited driving, i havent really pushed the car yet because i need a lsd but yeah
mikeoc1
109
Ft Benning
my n/a has the same really low oil pressure at hot idle, has 200k. It was that way 3k ago when I got it. It still runs fantastic, just old and a little worn out.
AJ'S 88NA
2,419
Florida
Rebuild it would fix it, if you run it till it breaks might cost you more to fix.
What weight oil are you using, I use 5-50.
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
This thread hurts my brain. Some people are incapable of listening. This poster is clearly in that category.
Put more Lucas oil in. Recommended amount is about 3 quarts, but more is ok.
You can also use a spoonful of moly grease in the radiator and a quart of water in the diff.
All of the above will boost performance and reliability just as much as Lucas oil... None.
Sent from my ADR6400L using Tapatalk
