No lights and other electrical problems
Mango
10
Barrie
So I am doing a 1j swap in my mk3 and the engine went in without a problem. The issue now is I have a bunch of stuff not working. here is the list
tail lights, break lights, Turn signals, Marker lights, reverse lights, tags lights, Horn, power mirrors, dash lights, all gauges and sometimes the green ring around the key. I have checked the grounds and they seem to ok. The car itself start and runs just fine. I have an apexi computer with an fc commander and all the readouts from it seem to be good eg rpm speed water temp and so forth. I would like to know if there is a common tread with all of these system to check first or do I have to go through each system to find the problem.
Ps I have already found http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual From other threads thanx its a great manual
te72
Classifieds Moderator
6,621
9
WHYoming
Man, Nick is on FIRE!
I'll feed ya a freebie though: make sure your hazard switch is plugged in, and your fuse box is wired up correctly. Might not hurt to post in the right section either. ;)
