NO HEAT!
Status
Not open for further replies.
huntin5L
Niles, IL
Well it is going to be getting cold here real soon, and im trying to figure out why i have no heat coming out, just cool air. I already replaced the thermostat, which i originally thought was a problem a while back because the heat would take like 10 minutes to kick on while driving so i replaced it. Now i get no heat at all.
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
yur heater vsv is prolly dead
its a valve that opens to let the coolant flow thru to the heater core.
its a little BOV looking thing above the turbo on the firewall with a hose coming out the bottom and one out the side and a little vacuum line coming out of the top.
isnms
United States of America
Oklahoma
i80.photobucket.com
bypass the heater vsv
huntin5L
Niles, IL
my engine temp is right on, im gonna go out there and see what im looking at, thanks for the pic. So you just have to take the hose off where you have the bottom arrow and connect it to the hose where the top arrow is?
huntin5L
Niles, IL
well, i went out there and i pulled the metal rod upward and heat started coming out. So i guess it is safe to say i need a new vsv.
isnms
Oklahoma
i80.photobucket.com
http://www.supras.com/06/techcenter/display.php?QID=67
Hot water valve vacuum solenoid valve (VSV) replacement said:
If your heater fan runs normally but there is no heat, the vacuum solenoid valve (VSV) probably needs to be replaced. With two exceptions, the VSV is energized anytime the engine is running which allows vacuum to be applied to the hot water valve actuator which in turn opens the heater core hot water valve. If the VSV is burned out, the water valve won't open producing the no heat symptom.
http://www.supras.com/06/techcenter/display.php?QID=58 Low-Cost Toyota Solution to VSV
*might find a cheap one on a part out in for sale form.
Yes, hook the two arrow points together
maitai69691
280
hilo hawaii
where does the vac line along the fire wall come from i dont have one lol thats probly my prob so i cant even do the bypass or will any vac work???
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
cwapface said:
I bypassed mine and I can't tell the difference from stock, i.e. heater blows nice and hot, and ac is cold. good job toyota!
lol, over-achieving as usual, aye, or just plain making a part that's not needed, just for the hell of it :biglaugh:
Status
