hey bro i can give u a few suggestions, first off idle the car for about 15 mins till the temp gauge is about at the middle (at least) and then find the two heater hoses, one on the driver side of the firewall and one is the one that attaches to the heater control valve (make sure the control arm is up so it lets water flow into the core) after 15 mins they should feel at about the same temp (HOT!). if those are what u feel the same temp, its time to check electronics, sit in the passenger side of the car put your ear close to the glove box area while you are increasing and decreasing the temp range from 65 to 85, you should hear a small motor actuating inside the dash which indicates the control door in the HVAC assembly working, let me know what you find out, if worse comes to worse i can meet you somewhere when the snow thaws out and help you diagnose the problem
